R
RSB
Hello All,
Has anyone got or used the Milwaukee metal cutting circular 18V? I would like to know how it compares to the Hilti
have used the Hilti and thought it to be an excellent tool however I have ever had much luck with Hilti tools, usually the have broken jut outside of their warranty.
I would use it for cutting unistrut,threaded bar.
The spec of the milwaukee only cuts steel @ depth of 1.2mm and wondered how it cuts strut(heavy gauge)
cheers
I think grinders and chopsaws are the favoured tools for metal munching, and a damn sight cheaper that a lovely expensive battery saw you are planning to use outside of it's capabilities.
EDIT: Having said that, this video shows it ripping through stud and strut no probs
https://www.youtube.com/watch?v=EClHAhVn14E
Get one, it's well shiny !!!!
cheers for the link Andy. You're right about chop saw's ad grinders but they need "Hot works" depending on the site and you may as well not bother asking.
The Milwaukee looks ok but I would like to know how it handles 41mm strut. I used the Hilti on a site but it got stolen. It handled our tasks just fine.
cheers
cheers
I have no personal experience to offer you I'm afraid. The video shows it, and recommends it for cutting standard strut. I have the standard 18V saw and that is a pretty powerful tool for a battery saw.
Makita do an 18 volt metal cutting saw as well. I don't own one but I have a Bosch 18v woodsaw which takes a slightly bigger blade and always wondered if I bought the metal cutting blade if it would work in the Bosch saw for sheet steel up to 1.5mm
cheers
not if they have tct blade, a lot of sites dont require a permit then.
it depends on the site though i have been on some sites where i was surprised i didnt need a risk assement and method statement to have a $hit
Not 100% sure how long your saw would last. The wood saws seem to spin at higher rpm's than specific metal cutting saws.
It seems site dependent for permits etc. 1st choice would be a chop saw but as said everywhere I've been has required a permit regardless of blade or everyone uses the chop saw destroying the blade. I prefer to have my own tools and a circular saw is more portable.
why would you use a circular saw? use a grinder, much better and you can swap the blade for masonry to do chases etc as well.
the only time ill use a circular saw is taking up floorboards
Evolution rage chop saws are a cold cutting 'one blade cuts everything' soloution
thats a tct blade.
a chopsaw with a tct blade can save a lot of time.
we did a job with loads of seggy 4X2 trunking and it cuts it cleanly with very little filing (same with unistrut) just make sure to use ear defenders/plugs as they make normal chopsaw blades sound quite
I checked and the rotation speed is identical it's just that the metal cutting blade is a smaller diameter so the speed of travel of the cutting tooth will be less. They're also similar power motors so I was tempted to give it a try, I'm just not sure if the centre fitting is the same because nobody around me has stock on the shelf that I can look at :(.
marvo you can get shims off the shelf if the bore of the blades are different
I have the 18v Dewalt metal cutting circular saw if I remember the spec correctly it gives maximum cutting thickness to be 3mm steel but I have used it to cut 6 - 8mm thick steel taking my time
RSB,
Robert Turnbull,
