Discuss KEW Snap 9 clamp type meter in the Commercial Electrical Advice area at ElectriciansForums.net
I have been given an old KEW SNAP 9 clamp type meter which is in good condition. The three amps ranges are working OK. The meter should be able to measure amp, volts and ohms. There are 3 small sockets (about 4mm) for leads to enter, but no leads. If any one got a users manual for this meter could I have a copy. Please send me a PM.Ted
hmmmm. no explanation around your eyes. 'bout right.
No wonder they wouldn't understand you their Japanese not Chinese
And using the free online translation sites won't help much either!! I know they are basically useless in translating either English to Chinese or Chinese to English, the grammar get's totally messed up when deviating away from the simplest child's type sentence...
Japanese maybe better, but never tried. ...lol!!
Problem with that type of writing is if you don't get it right and put another squiggle in it has a totally different meaning and instead of complimenting someone you could be totally insulting them.
Something along those lines...
Problem is you will only be inputting the English side of things, and depending how the sentences are constructed/worded the translation can be almost meaningless. I've tried inputting English getting the translation in Chinese, then translating it back to English. You'd sometimes be amazed at the results!! lol!!
arigato gazimas ^^ i cant spell it lol
Reply to KEW Snap 9 clamp type meter in the Commercial Electrical Advice area at ElectriciansForums.net
I know how I was taught to test a RCD, 6 tests in all two no go, two under 300 mS and 2 under 40 mS with no load. But thinking about it not so...
Someone asked about abbreviations used here. So I tried to copy a list I made elsewhere: A/C Air Conditioning AC Alternating Current ACB...
5K
Has anyone any knowledge on earth leakage clamp meters. As far as I can make out they are identical to a normal clamp meter only with greater...
I want to invest in one of these, it's primary function will be for me to measure the mA on circuits where IT is in use, it seems they can be...
11K
N
HI all!!!! Greetings from NEW ZEALAND! I am a quallified Electrician. I ask this question on these fourms , as my work mate is from Yorksure and...
5K
NZSPARK
N
