But why does the light still work when the socket circuit is diconnected from the CU?
More to the point why were you changing a CU when you should have been in church?
Perhaps it's the vicarage he was working in?More to the point why were you changing a CU when you should have been in church?
So you’ve left it like this until next week?
I must of missed that, where does it say that?
Recall that thread, don't know if it's been fixed yet! But the install is safer now with the RCD's and MCB's so all is good apparently!Of course he has, don't you remember this from the last time he found a fault on a CU change. I think it was a cable with a hole drilled through it he found and then left live for a while.
