Guest viewing is limited
Keyswitched fused spur labled fire alam supply normally by elec contractor but subject to initial contract agreement
keyswitched fused spur, this will allow you to cut the supply to the panel if you need to work on it. The spur must be labelled up 'fire alarm' and the norm would be to have them right beside the panel.
Just come off a job where 13 fire alarm panels went in, all had key switched spurs by them.
secret ones
Can't be that secret Jonnyb knows about them!
No, i,ve never bought a secret unswitched fuse, just wondring what secret wholesaler stocks em, if any one can tell me, much appreciated, is it at hogwarts wholesalers or summet.:)
The MK bits you refer to are from the grid range, basically build your own switch fuse spur (secretly!!)
I have never done it this way, been a few years since I did a new install on a fire alarm, is this the prefered method on sites now chaps?
thanks sintra for taking an interest and answering but without being pedantic over the page 537.3.2.1 it says devices for switching off for mechanical maitenance can be a number of things plug & socket, circuit breaker.I'm not advocating using a plug and socket.Also says the switch need not interupt neutral conductor.Not picking and grateful for help"its these ambiguous regs again"
You have got to love the regs.
The original post did state isolation not mechanical maintenance.
sparks1234
Hertford
Website
http://www.a2electrical.co.uk
Business Name
A2electrical.co.uk
Fire alarm supply
sparks1234,
Sintra,
