S
SPARK2B
Hi all, I am soon to start my 204 practical element of the 2365, most of you have probably already completed it, but i am guessing that some of you will not have dont it yet.
i hope the picture uploaded is of acceptable quality and size.
tray, trunking, pvc and conduit is already built
installation contains
a ring final containing 3x socket outlets and one fused connection unit (going through trunking and steel conduit
a radial wired in swa to supply a bs en 60309 socket outlet
lighting circuit in the pvc containing 2 x two way switches
bond gas and water pipework with a continuous conductor of the correct size
test the installation.
now im after some advice on the best way to attack this installation, and hints and tips, what to do first, make life easier etc etc that may be out there for it from both trainees and of course the guys running the forum!!
any and all help much appreciated,.....as always!! and thanks to matty for advice already given!
SPARK2B
be methodical. pull in the larger size cables first. i would do the pulls from the load end to the CU so that when you're coming to the last cables, the pull will be easier, as the conduit gets fuller the closer you get to the CU.
.....makes all the sense in the world!!
much appreciated!!!
SPARK2B
as its a ring, all cables have to return anyway dont they,....also iv numbered it 1,2,3 and 4, to avoid an empty return cable its going to have to be connected up i would assume in a different order, as we lose points for "excessive / unneeded" empty runs of cable"
im not questioning you tele, just trying to get it straight in my head
all help appreciated
SPARK2B
and i tape the conductors of each circuit together every 3 ft. or so. i'd check with your tutor first though, as some sparks don't like this.
for a ring, pull in both legs together where they share the same containment.
LUVVVITT!!
as for the taping, ...would not of considerd that,...will speak with tutor to see if acceptable
many thanks
SPARK2B
the reasaon i do it is so that at any point, you can see which L.N and E ( or with 3 phase L1,L2,L3,N & E ), belong to each other. useful when fault finding.
edit: different colour tape for each cct.
I have done this myself Tel when using singles and especially in the CCU to Identify incoming, and outgoing legs of the ring
I'm at college doing mine now! Just popped out for a cuppa then back in to start it proper. We already did a mock version of it a couple of months back for practice
we wanted to do a mock,...but been told its not allowed,...i would like to have!!!!
good luck pennychew, show pics!!
SPARK2B
Mines getting lashed onto the wall as once it's finished that's the end of the level 2 for us. All the other modules are finished now
