Am I right in saying that if there is a window then it doesn't need an isolator?
That's nonsense, whether you can see the fan properly or not without artificial light when cleaning or maintaining it it should be isolated.
Mcb could be isolated?That's nonsense, whether you can see the fan properly or not without artificial light when cleaning or maintaining it it should be isolated.
Which fans do not state that it needs to be fused down? Most I have come across do
I had a customer once that was adamant that she didn't want the fan isolator......it was an inline fan situated in the loft so I ended up putting it on a 4pin klik rose.
I phoned manrose about this, they confirmed to me that you only need a fuse in the permanent live and not switched live as its the permanent live that will have the draw on it from the fan and the switched live is literally a trigger, so they said fit a 3 pole isolator with a single fuse in the permanent live only.
what do you make of this? I tend to agree with it, plus if you are doing maintenance on the fan you should use the 3 pole isolator so it kills all power.
...such things are classed as LSC's and are not to be used for any other purpose,dont have the BYB to hand but 559.6.1.4 applies I believe.
