This is a reply I gave on a previous thread :-
In reply to the op it is possible to achieve fan isolation of all lives, fusing of both lines and have the bathroom light unaffected by fan isolation using just a dp sfcu and a dp light switch. The wiring is a bit 'busy'.
Supply into dp switch, two x two core cables to sfcu and one x three core from sfcu to fan. Connect as follows :- Supply l to dp light sw S1, n to wago in light sw back box. Using one of the two cores cables, light sw S1 to sfcu l supply, sfcu l load back to light sw S2. Second two core, light sw L2 to wago in sfcu back box, n from light sw wago to sfcu supply n. 3 core is connected to sfcu l load, sfcu n load and switched line to sfcu wago. The light is connected to dp light sw L1 and n to light sw n wago.
Description looks confusing but draw it out.
...such things are classed as LSC's and are not to be used for any other purpose,dont have the BYB to hand but 559.6.1.4 applies I believe.
