Whoever was responsible for that monstrosity needs a wake up call.
Quite simply pathetic.
now that could be going a bit too far. i can't imagine a plumber even getting the cables into the box without using push-fits.I'd go so far as to say not even a plumber could achieve such a mess !![]()
you ain't heard the end of it..here's a few more\:There's no need for that offensive language!!!
run pipes in front of sockets. fit radiator over a socket, mount boiler in front of CU, use sparks's joist holes for pipes, thread hot pipes through cables, condemn electrics as no cross bonding holding my boiler up.
My heart bleeds for you. I really feel your pain!! :laugh:
I don't think I'vever done any of those things - probably cos I used to run both the cable and the pipes at the same time so knew where they're going.
It's one of the advantages of being Multi-Skilled. :wink5:[/Q
ok, multiskilled is fine, but from a geordie, multiskilled is like having a bath and washing your socks at the same time.
Very true AND I can pick me nose & scratch me arse at the same time an' all.
