B
Bear2016
I have a job of running a new cable to a DBB. The 16A MCB is in place and the oven is rated at 3.9kw so needs to hard wired. The customer has tiled walls and will not allow me to remove them to run the cable. He wants the oven switch surface mounted.
I have approx 0.5m of cable from DBB to the surface mounted switch which will be for the oven
The switch is a fair distance from the oven but what would you guy recommend using as trunking for a surface mounted cable?
What do you call a fair distance? If it's too far then it defeats the object of the switch!
A good rule of thumb, based on previous regulations, is to keep it within 2m of the appliance it controls.
As for what to use as trunking then you could do worse than to use trunking! What type of cable are you using and what size is it? You'll more than likely want a bit of bodgers trunking
It falls just outside of the 2m I suggested moving it closer but it is close enough to do its job.
I was going to use 6mm cable T&E as have a roll of that left in the van.
Excellent idea. I use 6mm for all my 16A circuits. Can't be too careful.
Sounds a bit OTT to me when you're running from a 16a MCB and with the loading specified. Up to you though.
Maybe you need to consider how big the trunking will need to be to accommodate the 6mm T&E!
And there was me thinking you would have selected the cable size and type based on some calculations and consideration of the regulations! But of course using up whatever you have lying around in the back of the van is just as good as doing calculations.
Well one I have it in the van but secondly this is a second hand small oven for these guys and they are looking to upgrade to a bigger one later in the year when they can afford it. The trunking is temp until they re-tile the kitchen when it will be mounted in the wall. Now if the 6mm is 34A rated I can swap it over when the time comes onto a 32A MCB if need be. Just seem to make sense to me but hey what would I know I'm just a newbie at this to you oh wise great ones who proceed to flame every post that seems to be made :hurray:
You didn't say the trunking was only temporary, although if they're getting the kitchen re-tiled why can't you remove the tiles and chase the cable into the wall now? A half decent tiler should be able to remove and replace the tiles as they were anyway.
6mm still seems like overkill even if they're getting a 'bigger' oven - it may be slightly bigger, but still within reason. Remember you can run most ovens off a plugtop, and you can run a 20A radial in 2.5mm, which will be a lot easier to terminate.
