Hi,
If you can't find a ring booster then fit the customer a cheap PABX, it will do the same job for the ringing and stop people snooping on the phones. Radius 416 PBX Multi-Line Telephone System only £129.00 | Extera Direct
If you think it is the ring capacitor, then try fitting adsl splitters for each phone, the capacitor in the master socket is then redundant,
Lastly a single ding is often a sign of ring trip, the line insulation is breaking down under the high voltage of the ring, this then causes a DC condition on the line and the exchange thinks a phone has gone off hook to answer the call. This can be confirmed by listing to the ringing tone, if it stops then it is ring trip. It may be an idea to disconnect all the phones and the BT wiring and then do an insulation test at 100V
Have a read https://corporate.sky.com/documents/about-sky/policies/sky-pstn-network-interface-specification.pdf
Thanks UKMeterman for your comprehensive reply.
When it dings once the incoming call goes to voicemail. So the system must think the phone is engaged?? Is that a clue?
I'll check the insulation level of the circuits though.
All his phones already have their own filter or they share a filter. He has got bog standard broadband which seems ok.
Cheers!
Do a quick check, short out the line and is it the same voice mail, do one of the telephones have a telephone answering service? Also check the line current when all the phones are on the hook, the above document should give you a guide when all the phones are on the hook.
Get them to try a single simple phone plugged into the BT test socket for a week or two, and find out if the problem is still there.
Hi.
He uses external Talktalk voicemail. When it's working properly the phones ring 7 times and then the call goes to voice mail. When it's not, the phones do a single ping (which he doesn't usually hear) but the caller still hears 7 rings and then it goes to voicemail.
An 'engineer' has been and checked the system, but apparently didn't find anything wrong! I don't suppose he did the testing that I'm about to do!
Cheers!
Pete
extension bell unit off the line box. I have used them hard wire across, it is either 2 and 3 or 5 and 3. Turn off some of the ringing on the apps.
Ok,
If there are seven rings, then it is probably not ring trip as the line has not been seized, may be too many items to ring or a problem with the ringing signal from the exchange. Difficult to isolate, try with one simple phone into the test socket for a while. If customer is deaf perhaps rationalise the phones and put in 877905 | BT Adapter Ringer | BT it has the bell set from the orginal dial telephones, it startles anyone under about 35!!
Ok,
Hallo UKMeterman
He already has one of these bells! I'll see if he can do without some of the phone bells. I guess some of the phones will have a ringer off switch, otherwise disconnect the ring line. The PBX solution looks like overkill though my main concern is that he'll fiddle with it or chuck it out (He's a cantankerous old bugger!).
So...I'M STILL LOOKING FOR A REN BOOSTER. ANYONE? LOOK IN YOUR JUNK BOXES, PLEASE!
Will be there today giving the wiring a comprehensive going over, and testing line voltages, etc!
Cheers
Pete
Don't mind me while I bump some old threads. Just doing the rounds. Ignore the thread if it's not current topic, it'll soon drop off the list, but if the thread interests you, feel free to reply. :)
