If it's not been plastered I'd be enclined to replace a length of cable din to the socket (presumably) and stick a wago box above the ceiling.
if not particularly practical, crimp and a few layers of heat shrink and tape should do it.
Agree, I normally use online idea maintenance free connections and Wago box and chisel the wall to bury it so it will be below the plaster.
The heat shrink i use is really think, probably thicker than the standard pvc outer. I also use glue lined as it makes it quite solid.
UKSparks,
Where do you buy your glue lined heat shrink? none of my local merchants sell it.
I'd rather pull them back and joint in floor or ceiling. Couldn't be bothered on that job tho decorator was on my back
...Don't tell me you buy it? Don't you lot have tallow and killed-acids to hand?
Real men silver solder,braze,or forge-weld using river sand as flux :pirate:
