This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
Pete999
I know sweet F all about gas boilers so I need some help, all of a sudden when running the Bath the H2O goes from hot to cold, been ok for yonks.
N power engineer turned up today, and is trying to blame the new bathroom,a direct replacement of the old, I had a bit of a barny with the gas bloke, can't see how a new bathroom ( which was put in about 8 months ago) could cause this, anyone got any thoughts?
Does it do it every time you run the bath? If so then get the missus to run the bath while you check out the boiler, to see what happens.
It will be the hot water thermister either silted up or faulty. N power chap just didnt fancy getting his pants wet as its cold today.
Ps we have a Plumber on hear now that seems like one of the better ones maybe he will give you better advice
Thanks mate, thats what he came up with after I told him in no uncertain terms he was talking out of his backside when he said it was the new bathroom.
Has the 2nd Law of Thermodynamics only just recently arrived in your bathroom? :-)
Does this combi only do the bath water? What about all your other hot taps?
I'm a bit mystified.
Has the 2nd Law of Thermodynamics only just recently arrived in your bathroom? :)
Bath, Kitchen sink ,washand basin and C/H
Is this just when running the bath ?
Or are other taps effected ?
Which boiler is it ?
If it's just the bath, is that because you're running it longer than the basin/sink etc ?
Sorry couldn't edit the above, probably my computer skills
Its not an issue with mixer tap is it?
Mains pressure on the cold side slightly less than mains on the hot side due to the restriction of the boiler. Could end up with the cold pressure holding back the hot if the mixer exit is restricted. Limescale or the like.
If thats the case individual taps will work fine only the mixer one shows the issue.
You can test by running the hot tap of tge mixer only to confirm good hot flow. Slowly turn on the cold bit by bit. Eventually you may find the water loses all hot flow and is just cold.
Or as mentioned the boiler could have a fault but if so every tap should show that.
Glowworm 30cxi running the bath and sinks
I know I may upset you by asking this but I do need to, when you say sinks, are we talking about the wash basin in the same room as the bath or the kitchen sink ? Does this happen at all draw offs ?
Have you tried leaving the tap running a while after its gone cold or do you turn it off ?
If you turn it off try running it for two min just to see if boiler fires again.
( does the boiler actually go out or does it modulate down and keep running )
That particular boiler only needs 1 litre per min of flow to operate the flow switch and I am presuming you have more than that from your taps.
1 kitchen sink 1 wash hand basin and 1 bath hot water at all three outlets runs cold after about a minute
Got to be the boiler hasn't it?
Give it a bash with a big hammer. Unlikely to help but you'll feel better.
