Discuss Combi Gas boiler in the Central Heating Systems area at ElectriciansForums.net
Pete999
I know sweet F all about gas boilers so I need some help, all of a sudden when running the Bath the H2O goes from hot to cold, been ok for yonks.
N power engineer turned up today, and is trying to blame the new bathroom,a direct replacement of the old, I had a bit of a barny with the gas bloke, can't see how a new bathroom ( which was put in about 8 months ago) could cause this, anyone got any thoughts?
Does it do it every time you run the bath? If so then get the missus to run the bath while you check out the boiler, to see what happens.
It will be the hot water thermister either silted up or faulty. N power chap just didnt fancy getting his pants wet as its cold today.
Ps we have a Plumber on hear now that seems like one of the better ones maybe he will give you better advice
Thanks mate, thats what he came up with after I told him in no uncertain terms he was talking out of his backside when he said it was the new bathroom.
Has the 2nd Law of Thermodynamics only just recently arrived in your bathroom? :)
Does this combi only do the bath water? What about all your other hot taps?
I'm a bit mystified.
Bath, Kitchen sink ,washand basin and C/H
Is this just when running the bath ?
Or are other taps effected ?
Which boiler is it ?
Its not an issue with mixer tap is it?
Mains pressure on the cold side slightly less than mains on the hot side due to the restriction of the boiler. Could end up with the cold pressure holding back the hot if the mixer exit is restricted. Limescale or the like.
If thats the case individual taps will work fine only the mixer one shows the issue.
You can test by running the hot tap of tge mixer only to confirm good hot flow. Slowly turn on the cold bit by bit. Eventually you may find the water loses all hot flow and is just cold.
Or as mentioned the boiler could have a fault but if so every tap should show that.
Glowworm 30cxi running the bath and sinks
I know I may upset you by asking this but I do need to, when you say sinks, are we talking about the wash basin in the same room as the bath or the kitchen sink ? Does this happen at all draw offs ?
Have you tried leaving the tap running a while after its gone cold or do you turn it off ?
If you turn it off try running it for two min just to see if boiler fires again.
( does the boiler actually go out or does it modulate down and keep running )
That particular boiler only needs 1 litre per min of flow to operate the flow switch and I am presuming you have more than that from your taps.
1 kitchen sink 1 wash hand basin and 1 bath hot water at all three outlets runs cold after about a minute
Got to be the boiler hasn't it?
Give it a bash with a big hammer. Unlikely to help but you'll feel better.
Definitely boiler I'd say. changeing bathroom shouldn't effect boiler, only if flow rate is lowered a lot but it would need to be so low you'd notice. I mean a trickle.
Get him back ( or someone who knows what they're doing ).
It should be pretty easy to check it out. There's only a few of things it could be really. ( presuming heating is ok that is).
Thanks mate, I had the service company out, umed and ahed, Bathroom is the problem, dipstick, went away after ordering a thermistor and a pump FOC i hasten to add.
It can't be the pump. Pump does heating too. If it was thermistor, I'd expect it to be wrong temp e.g. To cool or to hot. Wouldn't normally fire, get hot and then go off and stay off. Sometimes if they are completely shot at, it might prevent it from firing altogether. That's my experience anyway. If I suspect one I normally ring tech line and they give different ohms readings at different temps as you probably know. Just to rule it out.
Thanks F14 is the code but it corrects itself if you turn the taps off
We had this problem every couple of years with our combi boiler was to do with hard water area BG engineer had something fitted which is cleaned out on service. Do you loose heating as well
With the heating off run the bath tap and leave it running while you go to the boiler. is --- firing? if yes, put your hand on the pipes underneath. One of them will be hot. That pipe will be the heating flow. If it is you have either a blocked plate heat exchanger or diverter valve problem. If the boiler is not firing then it might be the dhw thermistor.............but it could be something else.
Well thanks for that
Update. Gas eng been changed thermister, pump, stumped eventually called Glowworm help line, heat exchanger blocked. £450 for replacement and £600 for a system flush, so gettin on for a grand for repairs to a 10 year old boiler, going for new boiler. I had the exchanger changed 2 years ago, sod paying that money every couple of years
Remember pete I said the thermistor was scaled up or faulty:p or the BULB needs changing:rolleyes:
The thermistor clips on to the pipework can't see how it could be scaled up, nackered maybe, thanks for the input anyway, oh by the way all the LAMPS were OK
You didn't think my imput was of much help but it seems I was was right and the guy you had out was a dick.
A grand to clean the plate :D I will do it for half that...................or maybe a lot less.
You can't clean these plates it's replace or go without, what makes you think I didn't think much of your input/ although my reply may have seemed as a sarky reply it wasn't meant that way
I will post a photo of one being cleaned in a moment.
Yes that's the jobby, well I stand corrected will go to the naughty step for the rest of the evening, just a question for you, how long will that exchanger last until it's next clean, I realise that depends on lots of variables, just a ball park idea,
I don't often have to do them again on the heating side as usually it's dhw that scales up. If the heating system is fairly clean it would be several years. If it was dirty, I would put a cleaner in, drain and refill and expect several years.
The bloke you had out didn't know jack I'm afraid.
11 years about going to get it changed not BG a gas safe bloke I know and a 10 year warranty
TBH Pete I would consider that a wise decision. Boilers 11 years old, parts start coming obsolete/expensive if you can find them and you don't really want to start chucking money at something that's no far off becoming just that. Do you know what boiler your going for? The baxi ecoblue advance combi and the ideal vogue IMO at both good boilers and offering a 10 year parts and labour warranty if the boilers serviced every year by a gas safe guy and fills in the benchmark book. Make sure you get a decent magnetic filter if you don't already have one like a magna clean or fernox TF1. Might be the perfect time to upgrade the controls for maximum efficiency if they are of a similar age and put something in that has optimum start like a Honeywell CM921 or if you want to go all out a learning thermostat like nest.
Baxi increases warranty to 10 years on combi boiler - http://www.baxi.co.uk/baxi-increases-warranty-to-10-years-on-combi-boiler.htm
Vogue Combi | Combi Boiler | Ideal Boilers - http://idealboilers.com/installer/boilers/combi-boilers/vogue-combi/
Honeywell CM921 Wireless 1 Day Programmable Room Thermostat | Wireless Programmable Thermostats - https://www.plumbnation.co.uk/site/honeywell-cm921-wireless-1-day-programmable-room-thermostat/?utm_source=bing&utm_medium=cpc&utm_campaign=Bing Shopping - All Products - No Negs&utm_term=1100608002355
https://www.amazon.co.uk/s/?ie=UTF8...vqmt=p&hvbmt=bp&hvdev=c&ref=pd_sl_5i6sowpk6_p
Tell me Not into wireless stuff at all, but when I enquired about NEST controls the Gas gezzer seemed to um and ah is the NEST system Wireless? sorry for the what may seem a daft question, Mr Gas said it needed to be hard wired, can anyone enlighten me, from someone who grew up with switches marked ON and OFF with bloody wire in between
Reply to Combi Gas boiler in the Central Heating Systems area at ElectriciansForums.net
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
Hi all, first of all I'm not a sparks so forgive my ignorance. We are currently getting a boiler stove installed. This involves connecting the...
Just had a boiler put in on a grant scheme. Water main earth bonding was connected in with the existing gas bonding's pipe clamp on the outlet...
6K
Hello, I am looking at getting a solar PV installation (8 x 350W plus 4.6 kWh battery) and wondered how I might best take advantage of it when...
