O
Olestoepoke
Hi all, first of all I'm not a sparks so forgive my ignorance. We are currently getting a boiler stove installed. This involves connecting the plumbing and some electrical to our existing heating system. The Plumber has requested that our electrician installs a spur at the location of the plumbing system and a "Relay" from the newly installed pump and thermostat to our hot press. A wire that goes from the pump to the motorised valves and tells the gas boiler that the boiler stove is taking over when it gets to a certain temp. Is this a 4 core wire that connects two the pump and runs to the wiring centre in the hotpress or is a "Relay" something else. Anyone any experience with this type of thing that they could share.
The boiler stove system consists of two 8m pumps and heat hero box and a pipe stat set to 55 degrees (all to the right of the chimney breast). The pipe stat has a two core wire coming from it about a meter long not connected to anything yet, theres a fused spur there to power the pumps, so I presume thats all the connections are needed for the two pumps. In the hot press upstairs there is 3 motorised valves and an EPH wiring centre. Does the two core wire from the pipe stat get connected to a newly installed relay in the hot press and then a wire from the relay to the EPH wiring centre?. I wouldn't touch any of this myself, we have a sparks who has worked in our house on and off and he's a good guy but doesn't know what to do here, he has asked several work friends and I have spoke to another sparks and all stumped. Is there any way I could get a wiring diagram for this do you think? thanks very much for your comments and replies in advance
