With respect, would you not be better knocking this job on the head, and seeing if you can get some work with a local sparks as a mate? I know your friend is ill but if he is "going to change the CU" he should have done some basic tests first, 30 years exp or not. Even house bashing can be quite testing if you don't know your way around! You can't keep asking very basic questions every time you meet situations like this, you need to get some experience.
Thanks. Are you saying to try to run the cable along the joist? Which I would assume passes through the chimney breast? Won't this be a heat hazard if within the chimney breast, albeit behind a joist?
But even if I manage that... there is no 'other side' from upstairs. Take a look at the bathroom image.
I may be misreading you here.
Think I am misreading your pics, I thought the picture showed the cables dropping down to the "tiny" socket.
I don't think I have ever fitted one of those "tiny" MK sockets.
Shame you can't get some on site help from one of us, well maybe not me so you can bash some ideas about.
surprised this has not been suggested. if flooring above is tiled/laminate/whatever , not to be damaged, cut the bloody ceiling. easy repair and a muck=spreader to skim after.
Haven't read every post. But there's two ways to do this as I see it. The first is what @telectrix suggests - open the ceiling up. The second is chase around the top of the wall - within the 150mm zone - to get where you need to be, and then down to the accessory. There's no doubt a mess needs to be made one way or another.
You then have the problem of jointing the cables because they won't be long enough.
I think youre beginning to think. Of course it does depend on what way the joist run sometimes miraculously you can rod a cable through. I would be careful about where you locate the socket as it can be a pain trying to plug things in where that one is now.But at regs height it will be better. Depends where they are going to put equipment. But if they want to sell later then both alcoves will benefit. And usually there is a lot of sockets needed due to the plethora of equipment people want to plug in. Draw a plan of the whole ground floor and where sockets are needed then join the dots with your cable and work out the route.
Haha, well yes believe it or not I have given it tons of 'think'. Bloody keeps me awake at night.
But I am still confused how you can rod your way along the beam which runs into the chimney breast as it will surely give a heat issue?
And when it gets to the other side of the breast, I cannot actually access it as it is in a blocked off area in the bathroom as shown in the bathroom image.
Downstairs is simple once the cable is in place. Two sockets the other side of the breast and a double socket diagonally across the room. I would probably persuade them to keep the existing socket in fairness as it makes no sense to remove it. So both alcoves would have power... one day!
I have made it very clear it will be a total building site. :D
Presumably you mean to chase all the way round the 150mm zone and not across the top of the chimney breast? So almost a full lap of the room?
Ok you can not go through a chimney breast end of, there is no beam in a chimney breast you are going to go around it somehow.
You need your experienced mate all the way..
You may be desperate for work but this could be as complete and utter nightmare.
And if it's going to be a compete building site why don't you just recommend a compete rewire...It's probably for the best
I do lots of work with two local electricians. For over a year now. I also work for myself but survive on basics.
This would have normally been classed as 'basic' when I agreed to help him. Now it seems there is a lot more to it and I appreciate all the comments. In a way, it is probably a good thing the bathroom is blocked off or I would have already got stuck in [blush]
I am not offended one bit, but I don't actually need to work at all so not desperate. I just want to work. I enjoy it and love to help people.
I have mentioned there may be a requirement for a complete rewire which may end up cheaper in the long run.
I am struggling to stop my Avatar commenting, it might get him banned.
anycomment from ozzy should be treatedwith the respect it fu**in' deserves.
Richlizard,
Sparkie30,
