Just a cold room for storing old things, there's been no conversion ever done so it's literally just the space between the roof and the upstairs ceiling.
I was just thinking about loft insulation lying across the fitting, along with all the other stuff we have in our lofts?
Polish builders :p
It's been just a year since the install was done, when I saw the way that he had patched the other lights to one light I was pretty shocked as well.
New electrician is quoting about £15ish for each downlight that needs sorting, but like you said I think it's the way to go.
Polish Builders doing electrics :eek:
£15 each supplied, installed & wiring rectified?
Edit : Did the electrician specify what down light he was supplying
Whilst I'm not an electrician, I work in the AV industry so have a working understanding of a few basic things. Is anyone at all able to recommend a DIY style solution which I could do myself to aleast make the house a little safer?
Thanks,
Jamie
Thanks,
Jamie
Nope, get a suitably qualified competent electrician :)
PS; I would get that ceiling skimmed as well, for a proper finish.
Jamie Harris,
loz,
