H
hotfingers
There is a good write up by Thomas j.d agostino on the net about the cable I'm working with today I think am sure it's that
Most of the cable I have seen was manufactured by BICC (British Insulated Callender's Cables). As for the ccc I would keep the 1.5 to 6A, if the 4.0 are ring finals no reason why they cannot be on 32As but for a radial I would stick to 20A. Like I said this should ideally be rewired due to tunnel termination issues, at my site the client didn't want the expense (eight bed farmhouse) and my pic above is just the lighting board. You need to fit warning notices, as a matter of interest did you connect the aluminium clad conductors direct to the board terminals.That's exactly what I think Westwood lights 1.5 and sockets look like 4mm good man! What you think about ccc? This come from Texas components in the 70,s yes correct,would you issue Cert? Half the ccc of the cable ?also I am going to put a lot Less inspection period on the Cert as problems can occur a lot quick I should imagine
It is aluminium in the middle clad with copper.In my opinion the copper is the core on these cables surrounded by ally ......mine here are silver in middle with a slight copper on outside
Sent you a reply, may take some decypheringWhat about currant carrying capacity for theses cables then any ideas? Cheers
Look this guy up there are some charts in there some where with ccc comparisonsThere is a good write up by Thomas j.d agostino on the net about the cable I'm working with today I think am sure it's that
aluminium versus Copper current carying capacity chart in the UK - - Yahoo Image Search Results - https://images.search.yahoo.com/yhs/search?p=aluminium+versus+Copper+current+carying+capacity+chart+in+the+UK&fr=yhs-mozilla-102&hspart=mozilla&hsimp=yhs-102&imgurl=http%3A%2F%2F4.bp.blogspot.com%2F-IY_-BynAr0o%2FVR6jN6sMOeI%2FAAAAAAAAQ98%2FFuhnHXKjzI8%2Fs1600%2Fcopper-and-equivalent-aluminum-conductor-cables.png#id=4&iurl=http%3A%2F%2F1.bp.blogspot.com%2F-wxVa4zqNJ34%2FUnbWT5Q1X5I%2FAAAAAAAABeg%2FXrVjN_FiJZk%2Fs1600%2FTable%2B(1)%2Bcurrent%2Brating%2Bof%2BCopper%2Bcables%2Bat%2B86%25C2%25B0F%2Bor%2B30%25C2%25B0C.png&action=clickGreat I'll do that now, thankyou for your time cheers Pete
