There is a good write up by Thomas j.d agostino on the net about the cable I'm working with today I think am sure it's that
That's exactly what I think Westwood lights 1.5 and sockets look like 4mm good man! What you think about ccc? This come from Texas components in the 70,s yes correct,would you issue Cert? Half the ccc of the cable ?also I am going to put a lot Less inspection period on the Cert as problems can occur a lot quick I should imagine
Most of the cable I have seen was manufactured by BICC (British Insulated Callender's Cables). As for the ccc I would keep the 1.5 to 6A, if the 4.0 are ring finals no reason why they cannot be on 32As but for a radial I would stick to 20A. Like I said this should ideally be rewired due to tunnel termination issues, at my site the client didn't want the expense (eight bed farmhouse) and my pic above is just the lighting board. You need to fit warning notices, as a matter of interest did you connect the aluminium clad conductors direct to the board terminals.
Yes ally middle ,need to extend all cables to suit new board put in wagos same as westwood
Look this guy up there are some charts in there some where with ccc comparisons
