U
Uffledust
Hi all. Chatting with a friend earlier on and he happened to mention that his house has no RCD protection. Now this is an old house, he has never had any work done on it as far as I am aware of in the last 35 years. he owns the property but originally it was council owned. I am astonished that in this day in age he has no RCD. I haven't seen his consumer unit or intake so I can't verify what he does and doesn't have, maybe he has one external to the board covering all circuits? I have only ever studied electrics at 17th edition so to me RCD's are everything.
I was curious as to if this was common practice back then? When did RCD's start being implemented?
Uff
I'd bet that across the country there's more CU's without RCD protection that those with it. RCD's have been in use since the 1960's but were only really rolled out en mass in the UK in the last 20 years.
Hi all.
Uff
I suppose Rcds are a handy tool to supplement otherwise well protected installations;)
Mind you, evidence of mass electrocutions before popular use of Rcds can be much exaggerated
Maybe that is how we older types managed to live long enough to reproduce you millennium sparks :)
I know current operated Rcds were around in the sixties,maybe well before then (Chiltern was a popular brand)
I always get a bit worried,when it is assumed,that RCD's are a cure-all guarantee,of a safe and reliable installation.
Obviously,correctly installed,tested,and with the rest of the system,both upstream and down,in similar order,they offer an increased chance of a safer installation.
One of my properties,up until 2 years ago,was mostly vintage 1937,fused neutral head,with a replacement meter fitted 1960,and some minor wiring/switch fuse fitted,in the 70's.
It surprisingly,exceeded the current IR testing parameters,and had caused no issues previously.
In contrast,i have inspected many,many installations,fitted in the last few years or even weeks,where the owners visit their DB as often as their fridge,due to constant tripping issues,and how an injury or incident has been avoided,is a wonder.
On occasion,when bored,i will ask a spark,just how many faulty RCD's they have replaced. It is worth bearing in mind,that some of these defective items,may not have prevented a fatality,if expected to do so,in such an instance.
You can strip off,that old,tired cross-ply,that never let you down,because it is part of good maintenance.
But if the brand-new, low-profile,is not seated on the bead...the journey will not end well o_O
I think about late '70s early '80s when I was dashing and handsome, we started incorporating ELCBs in each house we rewired. Thought I was some kind of advanced scientist explaining to the customer what was happening...ah well.
Although i accept the "ELCB" part,as an attempt at increasing electrical safety,the "dashing and handsome",will have to be noted as "not conforming..." ;)
Hi my name is Edward, From ireland.
Back after long time,
interested in Discussion re ELCB's
Have noticed of late lots of faulty ELCB's mainly ones thad dont trip at all either with test meter of button.
Some not many too sensitive.
Think it important RCD's should be tested often,
I can remember my dad fitting a board in our house with an ELCB in 1987. Don't think it was the norm though.
I also installed RCD's in the 80's and I remember them being a bit hit and miss in operation and bloody expensive to buy.
I think about late '70s early '80s when I was dashing and handsome.............
Yeah, me too. If I was put through a full EICR nowadays there would be a few C3's and C2's on the list :(
