W
Will Russell
I've recently qualified and want to get myself set up with some new tools. I don't really fancy having some tools 110v and some 230v, if I can get away with it I'd prefer to have all 110v. However, I realise this isn't practical for domestic work as the transformer will probably take out the CB from the inrush current generated from it. So my question is, can you use 110v in a domestic situation without overloading the Breaker?
Normally fine from a ring final circuit. It's B20 radials which tend to trip half the time with a 3kVA Tx. As said if you reset it it's normally fine then. I have no 230V tools.
Consider Battery Operated - used to use 110v on site but now have a DeWalt 18V set and haven't looked back. 4Ah batteries or better easily last a day on a commercial site so will probably last a week on domestic jobs
Well 50% of the time it will trip and 50% of the time it will trip as you try and reset it (scarring the s#£@ out of you because you forgot it does that sometimes)
My box of Combi/Impact Driver/SDS and 3 4Ah batteries has never tripped a breaker and probably weighs less than a trannie (a stepdown one (before anyone makes a lewd comment)
i know its not my thread but am thinking of getting a cordless sds what it's like ,
I can understand the OP not wanting to double up on corded tools,110V being good for nearly all applications.
Why not modify the tranny with a thermistor? You-tube has various info-vids.
I did a 3.3kVA two tool TX 20 odd years ago,with the thought that i would only use it on a domestic supply situation,but it has been used to death. Heavy breakers,intermittent,overnight pumping,it has never failed.
I have not checked,but there must be new transformers available,with integral devices,to mitigate against inrush problems.
I wouldn't swap mine,for Mr.Izzard,it's done more miles ;)
Depends what type and size the breaker is
