N
Norfolk Enchance
Hi Everyone, I'm thinking of adding 4 double sockets to a ring question is can i use a 30mA RCD of one of the existing sockets then add my other 4 from the RCD ?
you'd need to fit a 13A RCD FCU,as you can only spur 1 socket outlet off a ring without fusing down.
Most definitely not - it's only the front bit of an RCD socket that's protected, not the terminals !
Edit - reply to OP, Tel nipped in before me.
Keep this for just this sort of question....
Norfolk Enchance,
Norfolk Enchance,
