Tel, you need more pens!
I replaced a tranny on a similar light to that around three years ago. Couldn't source the donut tranny except from Holland if I recall correctly, so opted for a normal 105VA tranny that would just about fit in whilst keeping the metal stud in place. I fitted lower wattage lamps to stop it overloading.
Unfortunately that didn't last that long either, so ended up changing it to a driver with LEDs. That has lasted much longer.
Those types of light fittings with the donut trannys are known to have a problem apparently, recall reading a post on a certain regs forum a while back.
