Midwest
I know this gets done to death, but just some light debate (see what I did there!).
Been fervent installer of JCC FGLED down lights, mainly because of push fit connections and ten year warranty. I have used some other manufacturers, Scolmore Inceptor, but mainly JCC.
However, recently my wholesaler has decided to stop stocking the FGLED6, because of failures. I've just used some Hybrid 9's, which were ok, but they being like the FGLED 10's are limited to no's on circuit and a bit pricey, so I'm looking for new manufacturers (didn't like the look of the Hybrid 7 lense).
My wholesaler stocks the Enlite E5 & 8, but another sparks told be they are a bit awkward to terminate.
What's your preferred weapon of choice?
I use ECO600's made by Eco-star, they're top notch kit and pretty reasonable on price
Never heard of them, look quite compact. Do they have an additional driver, or are they as displayed? http://ecostar.photonstarlighting.c...coStar_-_Eco600_-_Data_Sheets_V2017_03_29.pdf
They have a separate driver which comes pre-wired to a plug and socket connection similar to the click flow connector. They do the usual tilt, anti glare versions, emergency packs and suchlike.
They also produce an adaptor plate to fit them in to bigger holes from old eyeball fittings which I've found quite useful.
They also aren't generally available online, so if a customer wants to check the price they have to ask an electrical wholesalers. This way you know that the customer can't find them cheaper online and try to knock your price.
You sly old dog :) The only issue for me, is I see the drivers not coverable with insulation, which would be an issue for me, 'cos I mainly do kitchen and bathroom refurbs. Need a singular product. Thanks for the recommendation.
Done it a friggin again, defno need that drink :oops:
They look good DS especially the designed and produced in the UK bit.
The company was set up by photon star who make commercial LED lighting to produce smaller, lower priced products to compete in the domestic/small commercial type market.
I've been using them for around 6years and never yet had a failure,
I don't do much of this stuff but have kept the download because you never know.
I use ksr qr10 which are similar in style to the ones davesparks linked to.
They do a colour selectable model too.
I ve fitted quite a few E5 and E8s, there decent fittings that can be covered in insulation.
Install is slightly fiddly at 1st but does gets quicker.
Not quite as fast as a JCC!
Are any drivers suitable to be covered with insulation? Personally I wouldn't do it, they get hot when they operate and work best when they are cool.
The likes of JCC etc, are permitted to be covered with insulation. Their drivers are integral with the luminaire, and the design of it allows for air space around them to keep them cooler, allegedly!
Ok, that's what my sparks chum alluded to. See the lumen output compare to;
E5 to FGLED 3, E8 to FGLED 6 (ish) .
