You also have the main switch in the on position while the lid is removed with live exposed bus bar just waiting to be touched.Also no bushing around the incoming wires at the back of the consumer unit.
I think somebody has had a visit from the seal fairy!;):D
If using this for an assessment do not be surprised if you are asked how you safely isolated the supply to safely work on the install.
One of the things an assessor told me they do actually fail people for, if you believe anybody fails apart from a bounced cheque!! is that they do not safely isolate the supply and adequately lock/tag it off. This guy was a NICEIC assessor and also an assessor/examiner on the AM2, so bear that in mind and do you safe isolation procedure to keep him happy.
Yeah, that's a WT Henley ironclad service cutout (ISCO) with an ironclad sealing chamber beneath.
Originally it would have been double pole fused, but hopefully someone has put a solid link in the neutral by now!
Cheers dude. All the original cast heads round my way are resin/bitumen filled and sealed, with separate fuse carrier after the head. Hardly ever see fuses behind doors apart from the occasional pressed metal units.
I removed the busbar cover. As i was doing some testing
Henley also made the separate fuse carriers, but they all had sealed hinged lids over them.
Hahaha i think so
Not so funny when you kill yourself or some jobsworth at the DNO decides to chase you for a nice fine! I wont pull any of them old ones after i saw a Western Power Video of the state of some of them, even the DNO wont touch some of the ones around here they would rather cut the wire outside in the name of health and safety rather than suit up like a wannabe spaceman. the newer ones are a bit better if there is no load but always a bit of a gamble. just be careful.
Abu,
Midwest,
