FatAlan
Trainee
Would be interested to know from the experienced practioners out there what is currently considered the best domestic single phase make of CU.
I say this from purely selfish point of view as I’m about to embark on a 4 bed house refurb and likely to go for RCBOs.
Opinions based on access, user friendliness, quality etc. Any CU tarts out there that would consider a particular make / model the dogs b****cks of CU’s? :rolleyes:
I use Hager daily and have done for years. Very reliable switchgear in my opinion from a decent company with good history.
But! A large RCBO board will see you spending quite a bit on the gear.
I rate Schneider, but not the domestic range, the iC60 Acti-9 range. A single phase isobar board would probably be the "money no object" option for me.
There are much cheaper options than both of the above for RCBO boards
Hager if customer will pay for RCBOS or split load. Otherwise it is job specific, Have fitted a lot of Wylex split load recently as they were on a good promo at the suppliers.
Cheap rcbo I have used Live rcbo’s, on my own house I used an SBS double pole compact rcbo board, one rcbo was faulty out if the box but a replacement was sent the next day, very easy to fit!
