It's better than nothing at all. Working in control panels and designing them things like that stick out to me, as sad as it is.
Better, but green ferrules are for 6mm. Not only do they look better when properly ferruled, but it's against the regs not to!
Or 16mm if you like the German ones...
Either way those pictured are way too big and will not crimp correctly, even when you graunch them up with the screw...
then how come my 6.0mm ferrules are yellow?
You've been buying those cheap Chinese eBay specials haven't you? If so they'll be designed for 6.18mm cables...
had them for years from subbing to a major thyristor drive factory. they sat in what's called a "free issue" bin. i.e small parts that don't need to be requisitioned from stores. used there on panel building.
