Is there a regulation that states only to use bs7671 cable? I have come across alot of Chinese branded cable lately on my inspection and testing and wondering what to do about it? Tia.
Whats that?Is there a regulation that states only to use bs7671 cable? I have come across alot of Chinese branded cable lately on my inspection and testing and wondering what to do about it? Tia.
Y.o.g.w.y.p.f ?
I only say as I think the OP has a sensible question,
PRIZESpoints make prizes. what do points make?
The box is making more sense now !...... prysmium
it's like rebar when cold.
Whats that?
but are andrex installations notifiable? use of such could cause an explosive situation. are wiped turds subject to WEEE?
up here in the cold rainy depths of greenock all cable is usually like rebar except last week and this week so far 15 degrees C!!!! I feel like I'm on holiday this afternoon it was almost tops off Tuesday !!i hate prysmium cable. it's like rebar when cold.
Only my arm hairs are Ginge and I Houk up my kilt to air out my tallywhacker when the temp gets to double figuresYuk, A ginger thistle licker with his top off, might as well whip the kilt off and be in your birthday suit
BASEC surly plus a BS number I believe
I don’t think that Chinese cable would be good for our installs or our economy.
I’ve used Turkish cable from TLC and it was a pleasure to work with but still not good for our economy.
Prysmium take your cable out of the stupid box dispensers or at least try to run some cable out yourself before selling it to the people who need it to be efficient - my rant over!
Nothing, lovely to work with. Tested ok on the roll (the one time I tested it!)
Just that we should be buying UK manufactured items if we can.
In the basic principles of BS7671 it states that every item of equipment shall comply with the appropriate British standard or harmonised standard, if it is not then is must be of an IEC or appropriate countries standard; alternatively the designer is taking responsibility for the safety of the item being as good as or better than the appropriate standard.Is there a regulation that states only to use bs7671 cable? I have come across alot of Chinese branded cable lately on my inspection and testing and wondering what to do about it? Tia.
