K
KentSparky
is it dangerous to use the cpc in a twin / earth cable? I know it's not safe in case someone else thinks it's still an earth but is that the only reason?
Might not be the same csa as the Phase conductor, not insulated over the entire length, what are you using as the cpc if you bodge the job by using it as the N, IT'S WRONG and against the Regulations, nothing else springs to mind other than it's Muppetry to do it.
Commonly these are from a new member with a blocked profile :rolleyes: .
MODs... Is this 'blocked profile' a glitch as the last member who had this said they hadn't changed anything?
MODs. Carrying on from my text above:
I was curious if others also have enabled this feature. I when to the New Member Introduction section and it looks like the members who have New EF Member under their name all have this profile blocking feature enabled.
It looks like it might be a fault.
@Dan @Lou You may want to look into my post above regarding the blocking of viewing the profile.
It looks like its a bug.
Well .......... each cable should have a continuous CPC from the CU - can't remember the reg no.
Cpc has to be present at every termination but in fact you can get it from wherever you like.
You can even oversleeve a green and yellow insulated core with brown in a multi core cable and that still complies with the regs. But you'd only do that if you were struggling to avoid a lot of redecorating!
The bare cpc is not insulated that would be your main problem.
Same applies to any conductor that isn't identified correctly but that would show up pretty quickly in testing. The main issue is the lack of insulation and the requirement to get an earth to every termination.
