K
KentSparky
is it dangerous to use the cpc in a twin / earth cable? I know it's not safe in case someone else thinks it's still an earth but is that the only reason?
Might not be the same csa as the Phase conductor, not insulated over the entire length, what are you using as the cpc if you bodge the job by using it as the N, IT'S WRONG and against the Regulations, nothing else springs to mind other than it's Muppetry to do it.is it dangerous to use the cpc in a twin / earth cable? I know it's not safe in case someone else thinks it's still an earth but is that the only reason?
A bad joke at that.This has to be a joke
.Commonly these are from a new member with a blocked profile.
Cpc has to be present at every termination but in fact you can get it from wherever you like.Well .......... each cable should have a continuous CPC from the CU - can't remember the reg no.
Why is the profile blocked? has he something to hide? very odd.Commonly these are from a new member with a blocked profile.
Same applies to any conductor that isn't identified correctly but that would show up pretty quickly in testing. The main issue is the lack of insulation and the requirement to get an earth to every termination.is it dangerous to use the cpc in a twin / earth cable? I know it's not safe in case someone else thinks it's still an earth but is that the only reason?
