L
Leesparkykent
As above really. I normally set them up using wintex and it’s a easy....How ever I’ve lost my lead and couldn’t get one locally today. I’ve set it all up using the RKP and works a treat, the only thing I’m struggling with is naming the zones like landing, entrance, main office etc. is it possible to do using the RKP?
don't know the texacom, but is the keypad alpha numerical? e.g. key 1 for abc?
It is indeed, go into zone setup and keep pressing yes until you're at the device name screen. Press no and it will allow you to enter a device name (predictive text is on as default).
Thanks mate. Thought it would be something as easy as that....I think they’re really good panels but not that familiar setting them up through the keypad as I normally use Wintex.
i prefer andrex. nice and soft.
I like these ones .
join up to the Texecom Webb and they will help you to set it up .
I’m already a registered installer. Quicker to get the right answer on here though. It’s an office block I’ve just fitted out...it’s empty atm so just been back and wrote the text for the zones thanks to @Dobes_88 help. Turned the anti code reset off as not monitored and set the chime up on the entry/exit door.
