T
TomB
None as yet as i was only there to change the lights, plan to test R1+R2, IR, ZS and rcd trip. Also have the luxury of him putting it all in mini trunking so i can visually inspect everything as wellWhat tests have you done?
They have spurred off the rfc direct from the consumer unit
And, whats wrong with that?
She basically want to know if its safe and if i can do a report on my findings, she also doesnt want an EICR as the house is only a year or so old.
trade and standards .Initial tests found no earthing what so ever so i told her not to use the socket until it was looked into properly.
op has your client got any invoices form the said spark or it all CASH
Was it not you you who raise the non issue of spurring from the CU? if there is an earth problem get an Electrician to sort the problem outNothing in my opinion, the problem i have is that there is no earth in the socket
Agreed, thats not my issue though, the issue is no earthWhich is perfectly acceptable ......
No, was only there to change the lights so said i would come back as thats a seperate issue.Have you opened the socket front?
No, somebody asked me how it was spurred, or if it was a new socket... i assume they were heading down the lines of should it be an EIC rather than MNWCWas it not you you who raise the non issue of spurring from the CU? if there is an earth problem get an Electrician to sort the problem out
tell the client to get him back .Agreed, thats not my issue though, the issue is no earth
I'm now thing like miss maple now .who clubbed the cat in the drawing room .What were the initial tests that you came to the conclusion that it had no earth? or gave concerns by the customer.
