Hi
Does anyone know where you can purchase the earth clamps that the DNO use on their lead supply cables? I used to have a few but cant find them anymore and Im not sure of the correct name for them.
Cheers
Martin
No, Im doing a rewire and the previous install has a BS951 on it. Do you know where to get them?
Around here, WPD territory, to remove that, is a hole in the road, a live cut, then they remove the clamp and check the cable, if all is well, they sort the interior bit, then live joint in the street outside, that’s how seriously they take the danger from 951’s on PILC.
Kent
Website
http://www.mossep.com
Earth clamp for TN-S lead sheath supply cable
mossep,
MFS Electrical,
