P
peteski2019
Hi
Have bought led kitchen lights with extension cabling. Is it possible to snip the connectors in the picture off and just solder the led light to the longer cable?
Hi guys that's great thank you. I was worried the plug parts did something to alter the current or something and I'd end up soldering the wires together and destroying the light. As you say I'll mark up the cables from each plug on one side before I chop them so I don't cross them over. Then am I ok to solder and heat shrink the joins and call it job done?
I see. Personally I'd use e.g. Wago connectors in case you have to replace the lights or LED drivers in the future; they would also ensure insulation from each other.
