J
jon557
Hi,
Does anyone recognise this cable? Within it is all twin & earth but the externals are different colours (orange for 2.5, blue for 1.5 etc.). I believe someone told me this cable was specifically for being plastered over. Inside the cores have a lot of free air.
If I know what it's called I might be able to find specific grommets for a new CU I'm installing soon. Or I use the Wiska ones or I convert all cables to new grey twin/earth with a junction/marshalling box.
top entry or bottom entry ,or back entry, lol.:) just use closed whisker grommets .
Hi,
I don't quite follow this, why do you need special grommets to fit this cable? How would installing a junction box solve this?
orange is the new grey or blue is the new grey .
So the options I identified were:
1) Some sort of grommet specific for this oval cable
2) Perhaps the whiska membrane grommets work, never seen them before. Sounds like they will.
3) Worse case scenario I have a box next to my CU that crimps all these cables into new grey twin & earth, which would then be more normal for entering the CU.
I think Wiska it is. No one has recognised this cable yet then?
never seen it before!!
is there any particular reason why you cant use normal flat t and e cable glands?
got any pics for the old cu .
I think I'm stuck again, I need 9 cables to enter the new CU but these cables are 20mm X 10mm and most entry points are 20mm x 20mm.
I believe that it's not cable, it's singles inside sleeving, used in Local Authority builds in the 70's.
If I'm correct then they were factory made to fit standard unit sizes then laid out and buried in concrete floors and walls.
They are not cables as such more like a wiring system called OctoFlex or similar which never really took off.
Reactions: 123 and snowhead
why are you changing that board ?
  • Optimistic
Reactions: E.Swain
snowhead - You're right, I only just remember. Singles and yes this place is all concrete floors and these cables disappear into them.
I am changing the board for many reasons. I have 3 boards with eco7, all eco7 devices can now be set digitally to switch on so I don't want the multiple units/cables. One board is an old fuse board, I want rid of that. Only half the circuits are covered by RCD, installing all RCBO instead etc.
I'm also a complete geek so I'm putting in type 2/3 SPD, help protect my equipment but also trying an AFDD on my main ring mostly just out of interest.
afdd's and spd's????? more money than sense... fur coat and no knickers.
If the cable inside is Twin and earth, not singles as I thought, (maybe another system) then just trim the outer coloured sleeves off at the wall and treat the T&E as normal.
Reactions: jon557
sort the bloody thing as rear entry to the CU. if i doubt, squirt some funny foam.
Email
Time zone
Last seen
CU Entry, Old 1980s cable (?)
jon557,
7029 dave,
