DannyD
Hi guys, hoping for a bit of help. I just installed a Pyronix Enforcer 10 alarm system. I've installed a contact sensor on the front door. I thought I had configured it correctly: the panel has learned it and then I've set it to '7' i.e., "last exit". Problem is that it works fine on exit, but on entry it does nothing. I want it to trigger the alarm (on a timer to enable unset) - but it does nothing. I'm sure it's all in the settings but could anyone help? Many thanks for any help. Danny
Hi Buzz Lightyear, thanks for the reply. The only problem is that I'm too much of an ignoramus to understand it! Would you mind breaking it down for me a bit more? Yours, Woody (from Toy Story, not the other sort)
zone one is for entry and exiting the building the rest are programable zones if you read the installation manual its self explain.
Any zone can be used for final exit.
I would suggest looking at the zone in the diagnostics menu and ensuring it is showing open and closed. You should also get the 3 lights show on the contact when it detects the door being opened.
the only thing about that some customer s can not remember today never about tomorrow, say put on zone 4 on e/e and the alarm is triggered then when they look at the panel they get confused always zone 1 for me .
Thanks for the replies. I admit I'm still not sure what setting to change and what to change it to. If anyone could explain it step by step i'd be very grateful. I've read all the manuals it came with cover to cover. They don't really speak in zones except for the zone expansion feature. I've programmed the panel as follow: 'A': all motion detectors and the front door detector. 'B': all motion detectors (except for the upstairs ones) and the front door detector. The front door detector is set to '7' "final exit".
What areas are you setting? If you have put the door contact on A only but setting B then it wouldn't work. Door contact should be on Final Exit AB and maybe CD you also have 01 aswell. Over then that walk test the zone, check when you open the door you are getting Open and Closed on the panel, if all that works, delete zone and reinstall again
Thanks all. I reinstalled the door contact and now it works. But there is a new problem. The arming station by the door sets and unsets the alarm fine, except if you trigger the timer by opening the front door. And in that case it does nothing and I have to unset the alarm using my phone. Weird. Any ideas? Many thanks
I would check in assign keypads (I think that is where wireless keypads would be under) that keypad is assigned to set and unset the alarm in all area sets. If that doesn’t resolve issue I would ring for technical
Thanks for all the help guys. All sorted now. I called technical and they helped me out. Basically buried in the 'site options' menu there is a 'restrict pin use' option which for some reason is set to yes. Set that to 'no' and it works a dream. Happy days!
