Deleted member 26818
The new Regs apply to the CU, not the cable entry points.Thanks for all the replies. Looks like back entry will be the best way to go.
On a side note I’ve seen online that suppliers are selling the semi blind grommets which it says are ip66 rated for use on cu’s. Would these comply with the new regs as I haven’t seen this method shown anywhere?
Cheers
You only need IP4X/IPXXD on the top and IP2X/IPXXB on all the other sides.
Use IP66 grommets if you want, but there’s no requirement to do so.
