The price for a distribution board can vary enormously
You have to take into account what you are prepared to pay because it has a great influence on the type of board to fit
If price is no problem,then a full RCBO board is a must,if cash is tighter then the regs permit systems that comply but may not give the same ability to cause minimum disruption in the event of a fault
You may be advised to be open about what you can afford
Are you cash tight or is pounds no problem? :)
I have a budget as renovating complete house, so do not mind not having and rcbo board but happy to pay for the best rcd board that is currently out there :)
If you went Hager 14 Way non SPD RCBO board fully loaded with the new Mini RCBOs your looking about 300+Vat.
If you go that route though get a picture of the end product, will be like looking at ----. Not had a client willing to pay for one yet.
:oops: thats way out of my budget, ill stick to the one you recommended and look for the best price
Where would be the best place to buy from?
You're now going to buying a board recommended to you by a complete stranger on the internet rather than your electrician, perhaps mention the choice to your electrician before buying to make sure it is suitable.
Good point, but why would it not be suitable? I've uploaded a pic of my current CU if that helps?
It was explained earlier by the OP that the 7 way board pictured also had a shower and immersion boards that would be incorporated into the new board... so that's 9... Add futureproofing to another couple spare ways... that's 11... And now it depends on what size the manufacturer produces.
Hager does a 14 way, maybe a 12?? So a 13 way MK may have been a realistic suggestion.
Coincidently, I swapped an MK board last week to a 14 way Hager, full RCBO, with 2 spare ways.
Not cheap. But then, my customer's budget wasn't too limited!
The immersion and electric shower is no longer needed, but I'm guessing the immersion could be used as another wall socket instead
I thought he said they weren’t needed in the new unit....
edit.OP beat me to it
