Discuss Consumer unit upgrade in the UK Electrical Forum area at ElectriciansForums.net
Where would be the best place to buy from?
You're now going to buying a board recommended to you by a complete stranger on the internet rather than your electrician, perhaps mention the choice to your electrician before buying to make sure it is suitable.
Good point, but why would it not be suitable? I've uploaded a pic of my current CU if that helps?
It was explained earlier by the OP that the 7 way board pictured also had a shower and immersion boards that would be incorporated into the new board... so that's 9... Add futureproofing to another couple spare ways... that's 11... And now it depends on what size the manufacturer produces.
Hager does a 14 way, maybe a 12?? So a 13 way MK may have been a realistic suggestion.
Coincidently, I swapped an MK board last week to a 14 way Hager, full RCBO, with 2 spare ways.
Not cheap. But then, my customer's budget wasn't too limited!
The immersion and electric shower is no longer needed, but I'm guessing the immersion could be used as another wall socket instead
I thought he said they weren’t needed in the new unit....
edit.OP beat me to it
Reply to Consumer unit upgrade in the UK Electrical Forum area at ElectriciansForums.net
I was just googling for skeleton boards after reading the last thread and various pictures of consumer units popped up, some wired terribly and...
I try to keep out of Domestic work but I have a problem at home. Currently I have a wylex fuse board with re-wire fuses. they are great because...
4K
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
Just looking to see if anyone’s had a similar job or has any other ideas. Got a consumer unit to upgrade, the current one is fitted inside an...
I have a doorbell I want to install. The issue is the 16v transformer is designed to sit on a DIN rail. I have a 10 way 17th edition BG Nexus...
