Have a 220v (wired for Sweden) motorized pencil sharpener (Boston X-acto model 41). Since its a motor it does not work right, bogs down in 120v usa power outlet. What do i need maybe a transformer?
@devtinagub welcome to the forum I’m assuming you are in the US and it’s never going to work right plugged in a 120vac outlet when it’s internally wired for 240vac. Even if you had a transformer Sweden has 240vac on 1 wire with a neutral. If you want 240vac in the states it would be 2 wires which would burn the sharpener up. My advise is keep that one for your travels and just buy a new one.
Care to elaborate on that one? If you can find a 120-240 Tx or a plug adapter for a US 240V outlet I see no reason the motor should care where its power comes from. I would double check that the neutral on the sharpener is not connected to the frame, though it should not be.
A 120V - 240V step-up transformer is needed. Check the power consumption in watts and get a transformer of equal or higher rating in VA. Technically VA and watts are not the same thing but it will be immaterial for a small intermittent load like this. I expect the motor is a universal brush motor in which case the higher frequency in the US (60Hz rather than 50) won't make any noticeable difference. If it's an induction motor it will run 20% fast and may have slightly reduced torque.
Regarding connecting 230V European appliances to 240V US supplies, all modern products sold in the EU and compying with the regulations will function with two 120V hots rather than a 240V hot and a neutral. It is not permissible for them to require one wire to be a grounded neutral, since they must be compatible with outlets that do not have fixed polarity. However, their safety approvals may be invalidated by such usage so it might not be correct to recommend it.
A penknife will not function as a step-up transformer. Not even the 97-tool MegaSwissMaxiPocketBuster has a flip-out 100VA autotranny. It has a great selection of blades and countless other gadgets but won't help the OP sharpen any pencils :)
Beg to differ Lucien. Man was using a knife to sharpen pencils long before electric sharpeners were invented. ?
you can use a 240 > 120 backwards
to boost 120 up to 240
such transformers are readily availible
so much more response than i thought id get but for something id actually try just couldnt bring myself to any. probably because i had another solution to my actual problem (bought euro model hoping to be able to use since it was new) the gear on my us model was stripped. so just swapped gears;). now we have spare parts when needed esp. sparpening blades will be useful when these get dull. afaik motor/wiring is the only different part. thanks though did learn quite a bit. mostly parts are good but motors arent swappable with foreign powers.
North Las Vegas, Nevada
United States of America
230v european motorized pencil sharpener in 110v usa outlet bogs down
USA Electrical Forum
devtinagub,
devtinagub,
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
