If you are only having a 13A fuse in the plug then you should be using something like HO7RNF3C1.5 all the way so it can handle any fault current, also it might be simpler for ordering and neater to make it all the same.
How you connect and if you need a junction box would depend on the physical details of the lights, etc, and how you plan on laying them out. The dual 13A socket probably has multiple knock-out holes so you can easily wire in to one hole (with a suitable gland) and then daisy-chain out another hole to the lights if you go that way.
It is not clear from the picture of the lights if you could get two cables in to the back of them, or if the internal terminals will take 2 * 1.5mm wire. I guess you would need to buy some to check that sort of detail out.
If you do go for a junction box then make sure it is rated at IP65 or higher, and get suitable glands for it. Again, for all of the outdoor stuff try to have cables come in from below, or sides if you must, but not the top as its an easy way for water to get in.
[automerge]1585323341[/automerge]
Wago do an IP65 box, but bizarrely it is supplied with IP54 cable bushes:
www.screwfix.com
This box is cheaper but you need bushes for any cable:
www.screwfix.com
Here are some bushes that the Q&A says will do 6-12mm and the suggested cable is specified as 9.2-10.7mm so ought to work:
www.screwfix.com
But you can get similar stuff from Toolstation, CEF, etc.
Wago ABOX 221 IP65 32A 5-Terminal Weatherproof Outdoor Junction Box 110mm x 110mm x 67mm - Screwfix
Order online at Screwfix.com. Adaptable electrical junction box with Wago 222 Series connectors. Easy to use and provides a reliable connection for solid, stranded or flexible conductors. Ideal for lighting and power applications. FREE next day delivery available, free collection in 1 minute.
CED IP65 24A 5-Terminal Weatherproof Outdoor Adaptable Box 80mm x 52mm x 80mm - Screwfix
Order online at Screwfix.com. Adaptable boxes complete with terminals. FREE next day delivery available, free collection in 1 minute.
Tower Nylon Male Comp Gland 20mm 2 Pack - Screwfix
Order online at Screwfix.com. IP68. For terminating various cables. With neoprene rubber seal. FREE next day delivery available, free collection in 1 minute.
