rubbish. you need a ratchet crimping tool. price varies from DIY toos under £20 to professional one scosting around £60 -£80. generallyit's a different tool for non insulated.
No, the sizes at the top are wire stripping. They are not very good at that either :(
[automerge]1590066303[/automerge]
What kind of work do you want to do with them?
What are for then ?
I need to crimp car speaker wires.
Can I use one of these:
Knipex stuff is very good.
But even the low end ratchet crimps at £12-ish so such a great job compared to the nasty £4 pliers-type they are well worth it. The effort of fixing a single bad joint down the line pays for it alone!
These are like Rolls Royce of crimps.
apart from the quality. the jaws are a lot slimmer than most, so you can crimp each end separately without the tool overlapping to the other end.
I understand that good connection is desirable, but I can't afford to pay 50$ or pounds, or euros, just to crimp 2-3 wires. That's just not acceptable. I will crimp it with tool I have, or with the one I suggested to buy. I have tried them, and I am sure it will hold for longer period of time. If someone has better solution, then I will reconsider.
If you only need a couple crimped then why not pay a local sparky or garage a couple of Euro (or a beer) to do it for you?
Spending even 5 Euro on a rubbish crimp tool for a couple of connections only does not make sense!
It is for a speaker, the ones in #11 will be fine no ones life depends on it.
I tried to crimp this small wire into but connector 1.5 mm, but wire is too small and I can't crimp it good. I don't know what the size of wire is.
What should I do with the wire, should I fold it back down the wire insulation and crimp all of it?
You can fold back the conductor to crimp that with the metal part more effectively, but it is not a good idea to have any insulation in the conductor crimp section as the whole point of a reliable crimp joint is there is sufficient compression pressure to cold-weld the conductors together.
Not really. For a start they used different crimp tools - the "bad" one was not done with the correct style of crimp.
Also the red terminals should work for 0.5mm-1.5mm cable size, and if you double-back the conductor that is down to 0.25mm which is very thin, well below what is suitable for any sort of power (current rating around 2A or so). If the doubled-over conductor is not holding then it is simply a lack of crimp force!
I tried to even fold wire 2x, but I just can't crimp it good, connector doesn't even hold the wire, yet alone compress it.
I refer you back to the original discussion about how rubbish those crimp tools are :(
I tried tool in #1. I can see that crimping space is higher then in tool in #11. I can buy tool #11 but I don't know if that's going to be better. Honestly, I think wire is too thin to be crimped in but connector, I might have to consider some other joint.
It will not.
Look for a cheap ratchet style tool in your local DIY or automotive accessory type shops if you want something better.
Try folding the wire twice (i.e. to 4 * original thickness).
Use uninsulated crimps, solder the wire in and use heat shrink sleeving.
Could have done them all in less time than it takes to post on here ?
I don't know to solder.
I could only twist wires together, and use heat shrink with lighter.
[automerge]1590241197[/automerge]
What diameter of heat shrink sleeve should I use with there wires that are about 1 mm in diameter ?
Europe
All Other Countries (This Is English Speaking Website Only - WE don't mind Google Translate Users :)
Crimping tool
Electrical Tools and Products
Elecmox,
Mike Johnson,
