Elecmox
- Reaction score
- 17
Can I use this crimping tool for spade insulated and non-insulated terminals?
Discuss Crimping tool in the Electrical Tools and Products area at ElectriciansForums.net
Is that a no?rubbish. you need a ratchet crimping tool. price varies from DIY toos under £20 to professional one scosting around £60 -£80. generallyit's a different tool for non insulated.
yes a no ,proper crimps you need .not cheep teeth pullers .Is that a no
Can you post images what I need ?yes a no ,proper crimps you need .not cheep teeth pullers .
No, the sizes at the top are wire stripping. They are not very good at that eitherIs it on my tool where it says 1.5-6 meant for crimping?
What are for then ?No, the sizes at the top are wire stripping. They are not very good at that either
[automerge]1590066303[/automerge]
What kind of work do you want to do with them?
You can, they just don't do a very good job. They tend to mess up the terminals and it is hard to get the correct crimping force to make sure the connection is sound.What are for then ?
I need to crimp car speaker wires.
Can I use one of these:
These are like Rolls Royce of crimps.and here'sminefor insulated crimps. best ones i ever bought although they were about £65.
apart from the quality. the jaws are a lot slimmer than most, so you can crimp each end separately without the tool overlapping to the other end.These are like Rolls Royce of crimps.
Those are for ferrules, fitted to the ends of fine stranded cables.Are these good for crimping insulated or non-insulated ?
What about these?Those are for ferrules, fitted to the ends of fine stranded cables.
Reply to Crimping tool in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
