I came across a type of water heater that I haven't seen before. It has a 3 core flex attached and fits into the sink where an ordinary tap would usually go. I had to fail it as it had a two-pin continental style plug fitted and was being used with a unearthed adaptor.
My question is would it be a "pass" if it had a proper 13amp plug fitted?
View: http://i.Upload the image directly to the thread.com/gDa8Be6.png
depends if it's labelled classII or not.
Was it a 2 pin plug like this, with earth on the side and with matching adapter.
Or was it 2 pin like a shaver plug.
Plug as you show with earth on the side but adapter not matching (it would suit a two pin shaver plug). Cable clearly marked as three core.
[automerge]1591795203[/automerge]
No class 2 symbol as far as I could see.
therefore it needs an earth connection at the socket.
Common enough sur le continent...needs a matching earthed socket as stated above
[automerge]1591913736[/automerge]
The instructions are quite clear:
  • Package with a Socket Converter! Kitchen, toilet, etc ... All can use! Easy to install!
  • NOTE: DON'T test it in your hands before installing finished, that's would be very dangerous. Please operate it under the user manual."
Reminds me of the works of Keats or Shakespeare.
