Guest viewing limit reached
HappyHippyDad
Supporter
I have been offered some twin and earth cable at a good price. I haven't jumped at it as I want to make sure it's genuine first.
The brand is Ozler. It is 6242yh which is the British standard. Has anyone used or heard of Ozler before?
At £14 for a roll of 100m 1mm twin and earth I've just got a few alarm bells!
They are a Turkish company which doesn't necessarily mean anything. Only buy cable from reputable sources where you have some traceability should something go wrong.
Thanks Westward. Did you just do a quick search on the net or have you actually heard of Ozler before? If the latter, have you ever used it?
No I searched it never heard of them. Unless it has some traceability and is BASEC approved steer clear.
I think you're right. The 'Del boy' in me loves hunting out a bargain, but in this case I just can't be sure it's ok tempting as it is! :-(
Seems like they are a genuine cable manufacturer at least, but if you can't find a website with documentation to back up the claimed certification, then should something happen it might be tough to prove your due diligence in supplying suitable cable, so you are probably right to be cautious.
https://www.ebay.co.uk/itm/1mm-Twin-Earth-Cable-6242YH-100m-Drum-/362926618757
This is the stuff you are talking about I assume?
Agreed. If you can't get proof of the BASEC approval status and external traceable QM, there's no telling what the product actually is. Rogue cables have been found to have undersize condcutors, impure copper of increased resistance, insulation that was partially conductive or too thin... there are too many variables that you can't evaluate in a pub car park.
That's the stuff Dartlec. Ridiculously cheap, but it's just not worth it. The cheap price draws you in, then your morals and professionalism kick in :-)
I didn't really want to put a link up on this site as someone is bound to buy it, however its not exactly hidden on the net anyway.
That's the stuff Dartlec. Ridiculously cheap, but it's just not worth it. The cheap price draws you in, then your morals and professionalism kick in :)
Could always message the seller and ask them for the paperwork, it might even exist! Or send some to John Ward to test out....
At least if anything happens, saying you bought cable from a recognised suppler from a recognised brand shows some sort of due diligence, even if it's Toolstation or Screwfix.
"I bought it on eBay M'lud", leaves a bit more onus on you to prove you checked. Though of course there are some perfectly valid sellers on eBay and Amazon might be even worse...
But selling at that price suggests something must be different. Heavy discounts on discontinued products are understandable, but cable doesn't exactly change much...
Copper has a market price. The quality of copper in approved cables also has a price. If the copper in a cheap cable is less pure it will screw up your calculations and installations. If the copper in a cheap cable is as pure as it should be, and correctly sized, the saving must come from the insulation, which is not ideal.
Yes, you can find "offers" on well-known brands, but proper cable has a manufacturing cost, and a profit margin, and these are fairly constant. Cable at half-price will always have a question mark, unless it is a genuine disposal sale from a business closing down.
Was in an E5/JW video that they made mention of just because it's from Screwfix/Toolstation doesn't mean it's 100% kosher; the main reference being thier lever connectors, you know the ones - naff all compliance info on the website listing and I believe sod all on the packaging either.
Yep, one of the more recent E5 podcasts. I have some of the connectors in questionactually, and I think they came in a bag with no information at all... Nice idea though and I've so far only used them in 12V lighting or for temporary connections.
Though it *should* be reasonable to assume that someone in a company the size of Toolstation has done some due diligence....
10+ Years ago. When I was an apprentice, one of the boys in my class was on a job. There was a load of cheap Turkish cable bought. (However, I don't know the brand, Ozler could be decent)
There was dozens of rolls installed and then they had to be ripped out because the cross sectional area was not consistent throughout the cabl
Proceed with caution
Edit:
https://www.bbc.co.uk/news/uk-41391343
It was Atlas Kablo which was used
Just received a few rolls of Pamukkale Kablo from EDs , I've asked for it to be collected and refunded of exchanged for prysmian . Having stood before a court appointed technical adjudication once before I'm not prepared to risk going through that again...for he sake of a few pence e on the price of a roll.
Though it should be reasonable to assume that someone in a company the size of Toolstation has done some due diligence....
Or not, given how defensive and closed ship they are when questioned on the subject.
I have received the same from cef. Probably buying it cheap.
Edit:
Millions of metres of dangerous cable 'in homes across UK' - https://www.bbc.co.uk/news/uk-41391343
I remember working briefly for a firm in the early noughties that was using "cheap turkish dogs hit cable" according to the guys that worked there. Probably all came out the same factory!
I'm sure these companies are set up to knowingly sell second rate goods knowing that the regulation is many years behind the curve so when they eventually catch up the scoundrels abandon ships having made all the $$$$
Trouble is people up there be too stuck up to speak to the guys on the ground who know whats happenin.
HappyHippyDad
Supporter
Gloucestershire
Ozler cable 6242yh, anyone heard of ozler?
HappyHippyDad,
Teddy Lop,
