Hi Everyone,
Thank you in advance for your assistance, I"m assuming that having an unenclosed main switch is against the rules ?
Should it be sited within the same Consumer Unit or a separate enclosure ? The Consumer Unit, meter and main switch are housed within a wooden formica cupboard (2nd photograph).
Many thanks for your advice re any necessary changes that need to be commissioned.
Regards, Paul
That is the DNO isolator switch look at label fitted by Morrison data meter installer
Hi Everyone,
Regards, Paul
Whoever did the initial install of the M/S needs shafting with a prickly stick, preferably without an anesthetic.
Could always put a lock on the cupboard door if concerned about it !
I'm failing to see any real issue with it
What about inquisitive children getting their grubby fingers and the like in the open terminals? not a good idea is it think about it. a bad move in my book , but mind you I am old School and value the safety regulations. fallen foul of the a few time myself, not good seeing a nipper that has stuffed his/her carbon pencil into anun covered terminal with 230 Volts hanging on the ed of the pencil, could you live with it
' I couldn't your choice Mate
