Tempted?Nice one. Surprised Westward didn't pick you up on your earth sleeving though!
And by the way, I wondered where my level went.
Yes you only need to test the rcd for the rcd results, that way you get a clean result. The circuit is not relevant for the rcd testDo you mean that, it test the RCD, but does not test the circuit will be protected by the RCD, or am I missing something?
i have 2 alternatives.dependent on the condition of the dNO fuse assembly, and presence of seals.Dare I ask how you managed to fit the new tails, Isolator already there???
It isn't. The cooker is on a 32a. It is in conduit for approx 1.2m then is clipped direct to the skirting board before chased into the wall to the socket (don't ask, I didn't install it! ?) Total length of the cable is approx 2.5m to the switch then approx 1.5m to the cooker terminal.Not sure I would have that 6.0 on a 40A as it is contained in conduit.
Can you give a valid reason for this.[picky]B40 first on the busbar, not last.[/picky]
