To avoid an uncessessary inaccesible fuse behind.
Yes, many do know that. But a purpose made item is better.
Have you thought about looking at this from a different perspective, rather than fixating on one particular 'solution'?
Say behind a fixed integrated washing machine. It is not going to be plugged into anywhere else. The best is a 15A round pin and shuttered socket behind the washing machine. The problem is awkward manufacturers wanting to side step their warrantee obligations, otherise a 15A round pin is the best choice, which cannot be plugged into anything else.
The question was, where are these solid links available?
Why in the absolute tosh does anyone care? Plug the thing in and go live your life.
It eliminates an hidden and uncessary fuse, when one is there on an FCU.
So which Regs are you referring to I ask again.
A fuse will rupture due to a fault condition so how does fitting a link to an "inaccessible" fuse make a difference.
Why is the appliance, which comes with and is therefore designed to have, blowing 13a fuses in the plug top in the first place?
The common response. Some fuses just fail. Not a lot, but it does happen. Best have fues easily accessible - which is common sense.
Utter tosh
becomes dangerous as soon as it’s plugged into a different socket that is not fed from a 13A spur.
Read back. Behind heavy non-portable appliances. When pulling out it is easier to unplug as well.
Which proves you are trolling again. Surely everyone knows this right?
The only troll here is YOU. You have been provocative from the beginning.
Now back to the prime point of the thread. Do you know where these solid links are available?
John-SJW,
westward10,
