Discuss Replacing a 13A plug fuse with solid brass in the Electrical Forum area at ElectriciansForums.net
Status
Not open for further replies.
Anyone got a copy of BS1363 and can look up solid links?
Why would you need a solid link in the plug of an integrated appliance? Besides you don't buy solid links you just cut the head off an m6 screw/bolt, everyone knows that.
To avoid an uncessessary inaccesible fuse behind.
Yes, many do know that. But a purpose made item is better.
I have the feeling BS 1363 is not BS 1363 once a solid link is pressed in, as the fusing is removed.
Therefore not permitted for use as it no longer complies. Case close.
You can get a solid fuse replacement in other sizes, mostly much larger, though I did notice a 20x5mm size:
"A solid fuse replacement slug, 5x20mm used to remove/replace a fuse terminal fuse with a straight-through option. Solid links can be used when trying to trace a fault in part of the electrical system."
Haven't seen any in BS1363 size.
Not a manufacturers item for sure, but looks safe enough if well clipped in making a sound electrical connection. And to regs if the plug is after an FCU. Nicer to have a purpose made product.
Which proves you are trolling again. Surely everyone knows this right?
Why is the appliance, which comes with and is therefore designed to have, blowing 13a fuses in the plug top in the first place?
Reactions: DPG
Have you thought about looking at this from a different perspective, rather than fixating on one particular 'solution'?
Reactions: DPG
Say behind a fixed integrated washing machine. It is not going to be plugged into anywhere else. The best is a 15A round pin and shuttered socket behind the washing machine. The problem is awkward manufacturers wanting to side step their warrantee obligations, otherise a 15A round pin is the best choice, which cannot be plugged into anything else.
The question was, where are these solid links available?
Why in the absolute tosh does anyone care? Plug the thing in and go live your life.
It eliminates an hidden and uncessary fuse, when one is there on an FCU.
So which Regs are you referring to I ask again.
A fuse will rupture due to a fault condition so how does fitting a link to an "inaccessible" fuse make a difference.
The common response. Some fuses just fail. Not a lot, but it does happen. Best have fues easily accessible - which is common sense.
Status
Reply to Replacing a 13A plug fuse with solid brass in the Electrical Forum area at ElectriciansForums.net
