Utter tosh
becomes dangerous as soon as it’s plugged into a different socket that is not fed from a 13A spur.
Read back. Behind heavy non-portable appliances. When pulling out it is easier to unplug as well.
Utter troll. Read his previous posts.
Reactions: Dave OCD
  • Funny
Reactions: James and DPG
Which proves you are trolling again. Surely everyone knows this right?
The only troll here is YOU. You have been provocative from the beginning.
Now back to the prime point of the thread. Do you know where these solid links are available?
No. I do not. Ebay? Alibaba? You tell me
I will sell you as many as you like for your own personal use.
£12.50 each with a minimum order quantity of 100.
lead time 14 days.
Are you going to tell me which Regs you refer to in #8.
Reactions: nicebutdim and DPG
No sir, precision turned brass.
made by a uk manufacturer.
I'd buy some John. They will do what you require. Problem solved. No need for any more posts right?
  • Funny
Reactions: Dave OCD and James
I answered that. The regs we all go by.
There are many of them, if you could list one it might help.
I assume by your lack of response that you don’t know what regulations apply in this case?
Reactions: Spoon and DPG
There might be a reason they are so hard to come by.
Have you thought about looking at this from a different perspective, rather than fixating on one particular 'solution'?
Will you suggest another solution.
A 15A round pin is suitale but it us the shark makers warrantees that is the problem
Trolling I see.
Why would you ever need to access such a fuse? if it has blown the appliance is faulty and will need to be pulled out to repair it anyway, at which point the fuse becomes accessible...
Doesn't even make sense. And you are just avoiding the questions asked.
Reactions: Dave OCD
Email
Time zone
Last seen
Replacing a 13A plug fuse with solid brass
John-SJW,
westward10,
