I gracefully disagree , I have watched most of my videos as I can't see much wrong with any of his workmanship
He is neat , tidy and often takes on awkward jobs that aren't easy to make look perfect
He could things faster sometimes but at 65? he does okay imo and I love the way he talks through what he is doing and explains why he is doing it that way
He's 65? Wow he's aged well, thought he was about 50.
I watched a couple of Leroy's videos he's definitely old school... Seems like a good bloke but would probably benefit from some newer methods.
I think this is the very fact why most don't like him, all the newer generation, nothing wrong with old school methods .
His name is Delroy
Are his 'ways' really that ole fashioned ?
Most of what he does he learned in the 70s and 80s
I learned similar ways in the 90s
The only thing to change is some of the tools we have now like wall chasers
I really don't know what you lot are doing,wasting all them hours on Youtube,watching all them amateurs....
There is one,and only one dude on Youtube,and as we all know,it's Taryl Fixes All.
Now then,there's your dinner ?
I suppose equipment and methods have advanced massively
Speed of thought and implementation of various methodologies available are key
You see it here all the time, there's a faster and better way of doing every job now if you know what it is and have the right equipment and materials
I thought it was apparent that he didn't use his mft that much. I don't think many people would have his tolerance for these knackered systems or would want to take the responsibility. I get that customers don't want to spend money though and he needs to provide what the clients want.
I've only watched a relatively small number of Delroy's videos and, oddly enough, his MFT appeared in most of those.
I have only seen a couple so I might have the wrong end of the stick. He used a voltage tester a lot on one and didn't seem that confident on another. Personally I prefer to conduct tests and identify the fault before taking things apart incase I accidentally cure the problem when all the wires pop out and end up guessing. It also might be the way it's edited and it's all easier as an outsider.
I picked up on that too, he was using a voltage tester checking earths at outlets
Tells you nothing about the fault loop
